Error after update 4.4.1.5
Barry
Post by Barry »
Hi there,
Today i'm starting Proppfrexx and the screen says..... there was a update.
After the update Proppfrexx is not starting and nothing is working.
Is this a small issue?
Re: Error after update 4.4.1.5
I just tried it here and it worked without any issue.
Maybe the download or the previous shutdown was not complete?
Pls try a reboot and try again. If that doesn’t help, try to reinstall the regular download - no settings will be overwritten with a reinstall.
atlantic
Post by atlantic »
After the update PF no longer works. Even after restarting the PC.
What error do you exactly get, as here the update works on my test PCs...?
Barry
Post by Barry »
Thanks for helping.
I Re-Installing PF and it is working. (Old version)
When i Click also on Update.... Nothing is Working. Also my friends have the same propblem with Updating. (All Legal and original key)
I try 3 times this Evening and PF is not starting. For now.... I'm using the older version. Hopefully it is a small bug.
I check some things... (System say PF ONAIR was terminated or was Killed ) :?
atlantic
Post by atlantic »
After the update, PF no longer starts and you don't even get an error. PF does nothing anymore and the startup logo does not appear on the screen. If I start PF from the Previous Version folder, PF works, of course the old version.
I copied all files to the ProppFrexx ONAIR folder and the PF works again.
Very odd! I will then first remove the update to investigate...
I just rebuild everything and provided a new build to download.
As such the v4.4.1.5 is up again - I even saw, that some users already successfully used v4.4.1.5 ... so pls try again.
atlantic
Post by atlantic »
Update works as it should. PF start after the update.
Thank you very much Bernd.
Cool! THX
