Volume Points for specific playlist
Osric
Post by Osric »
Hi , I was hoping for some advice.
I've created a voice track and have added volume points to an underlying track in my playlist. However, I'd like the underlying track to play normally (i.e. without the volume points) automatically when used in other playlists (that are not voice track related).
I can't seem to find the way to toggle this type of function?
Any assistance is much appreciated.
Thanks
Re: Volume Points for specific playlist
That is exactly the reason, why ProppFrexx has the option to:
- Save Meta Data as TAGs (to the audio file)
- Save Meta Data as File (as an extra file along with the audio)
If you DON'T do the above (and also don't save that meta data automatically, which is the default), the meta data (incl. the cue-points and volume points) are ONLY saved to the playlist! I.e. this meta data is only valid for the segues of that playlist.
Or in other words: In your case, NEVER
- Or automatically save cue-points and volume-points in the general settings
See here for details:
viewtopic.php?p=10
viewtopic.php?p=18
