Log of sound sent from Master channel
This forum is unmoderated!
kimmelim75
Post by kimmelim75 »
Is there a logging option in ProppFrexx? Record all from Master channel. Divided in files of own choice?
Maybe its called something else?
kimmelim75
Re: Log of sound sent from Master channel
Aka, record to file.
Sure there is. See the general settings, section Recording/Encoding, for Automatic Recording.
But note, that there is no master channel or output. You can record each resp. the related mixer output or input channel, which you would like to record, eg. the one from which you are streaming.
The separation (sensing) can be done time based, eg. per every hour or split per new program.
Also make a right click on the resp. mixer channel to see more options. But all major settings are done in the general setting as mentioned above.
