v4.4.1.0-.6 - stable
Version 4.4.1.6 is out!
What's New?
  • Swap Selected Playlist entries added
  • New EXEC_VAR_SET_DIALOG command added
  • New UI- and Audio-Lib version
  • Bug-Fix with PFL Player and the SND2@NoPFL function
  • Bug-Fix in Program Scheduler Playlist Pre-Generation
  • Bug-Fix when the main window might be hidden when a popup is closed
  • Bug-Fix in SCHEDULER_PLAYLISTEXPORT_PDF
  • Multiple Advert Campaign Keys are now supported
  • Campaign Keys are not honored for Priorities above 100 and below 0
  • The program bridge track now supports endsAt exactly (negative Min.Bridge Time)
  • Command SHOW_COUNTDOWN 0 will discard last countdown dialog
  • Program TimeUpdateSync handling for embedded overlay containers optimized
  • Various optimizations and smaller bug-fixes
  • stable
Re: v4.4.1.0-.6 - stable
Note, that I am thinking of dropping 32-bit support for ProppFrexx, as every OS is 64-bit today...
So are there objections? Does anyone strictly use or need a 32-bit version?
Vladimir
Post by Vladimir »
Hi, the soft advise new update 4.4.1.0.-7 but no notice there ... ???
The v4.4.1.7 only included a fix in the Tagger application. See here: viewtopic.php?p=18624
That’s why there is a new build .7 available, but not really listed here.
