Scheduler
djbony
Scheduler
Post by djbony »
Hi, I have automatically recurring events on my calendar on Friday, Saturday and Sunday evenings. I always have to manually erase the green ones so that the pink ones play out properly. Is there any way to set the priorities so that I don't have to edit it manually? Thanks.
Re: Scheduler
No. Program scheduler entries should be by design unique and mutual exclusive. They can not happen in parallel, like overlay entries.
I can not see your recurrence pattern, but you can define the Clock 1 and Clock 2 entries for 20:00:00 and 21:00:00 to recurre every week on Monday, Tuesday, Wednesday and Thursday, but not Friday to Sunday?!
djbony
Re: Scheduler
Post by djbony »
Clock 1,2,3,4 are repeated periodically every 4 hours. Every Friday, Saturday and Sunday at 20-22 I run a special (in pink). However, in the scheduler, it is not possible to exclude the time when it meets...
Re: Scheduler
It is possible.
You simple need to create for each day individual entries, which do not repeat every 4 hours, but daily.
Yes, this results in slightly more entries in total, but prevents those parallel entries.
And is not really critical, as it is just configured once.
djbony
Re: Scheduler
Post by djbony »
I'll try it. Thanks for advice. I didn't think of it from that point of view :)
