Issue with 2 players playback
Kyle FM
Post by Kyle FM »
Hello
I am using ProppFrexx in the 2 player mode instead of 3 player mode to save a channel on my mixer. This is causing a problem.
If the OUT-cue point of player A does not end before the NEXT-cue point of player B the next track is not loaded in player A until the OUT-cue point is reached.
Is there a way to eject the track on player A (or B) such that the NEXT-cue point of the other player actually triggers the next track and it does not wait for the OUT-cue of the previous track to be reached?
Re: Issue with 2 players playback
No. Just use 3 or 4 players.
Note, that you can route the DJ Players to the same output device if needed.
This behavior is by design. And works as it should be, as you defined/set the cue-points like that.
A new track is and can only loaded when the cue-out point is reached. Else the track would be cut off while still playing.
