no audio
Radiostar929
no audio
Hi Bernd. I have a problem; I no longer can broadcast live from my console into your software. Windows mad a update on May 22nd and since then there is no input into proppfrexx do you have a remedy for this? Have I not something punched into the program? Im a bit concerned. Tom
Re: no audio
Nothing changed and I simply guess, that your sound devices got new IDs, drivers or alike.
Eg. simply rescan your sound devices in the general settings, section Inout/Output and then reuse and assign the correct devices. That’s all.
No function or limitations have or will be added to ProppFrexx!
