TCP socket concurrency
Thijmen
Post by Thijmen »
Dear,
I have a background worker in C# code which interacts with ProppFrexx with the TCP client.
Sometimes, I send a command en retrieve the data, but I get input from another command.
Is there something possible to combat this?
Hereby my proof of concept code;
using System.Net;
using System.Net.Sockets;
using System.Text;
var serverIp = "192.168.1.112"; // Replace with your server's IP address
var serverPort = 8052; // Replace with your server's port number
var serverEndPoint = new IPEndPoint(IPAddress.Parse(serverIp), serverPort);
using var client = new TcpClient();
client.Connect(serverEndPoint);
void SendTCP(string msg)
    var message = $"{msg}\r\n\r\n";
    var data = Encoding.ASCII.GetBytes(message);
    client.GetStream().Write(data, 0, data.Length);
string Receive()
    byte[] buffer = new byte[1024];
    int bytesRead = client.GetStream().Read(buffer, 0, buffer.Length);
    string response = Encoding.ASCII.GetString(buffer, 0, bytesRead);
  //  Console.WriteLine("Server response: {0}", response);
    return response;
void GetEntries()
    while (true)
        SendTCP("AUTHORIZATION password");
        Receive();
        SendTCP("PLS_CURRENT_GET_ENTRIES");
        Receive();
void GetName()
    while (true)
        Receive();
        SendTCP("PLS_CURRENT_NAME_GET");
        var data = Receive();
        Console.WriteLine($"current name: {data}");
// Create two threads
Thread thread1 = new Thread(new ThreadStart(GetEntries));
Thread thread2 = new Thread(new ThreadStart(GetName));
// Start the threads
thread1.Start();
thread2.Start();
// Wait for the threads to finish
thread1.Join();
thread2.Join();
// Close the connection
client.Close();
Thijmen
Re: TCP socket concurrency
Post by Thijmen »
I guess there is some max length of the socket (Is it 1448 perhaps? :)). I need to do some while loop to fetch resuming data in the socket before I send a new command. PLS_CURRENT_GET_ENTRIES returns more than my buffer length (even if I do 1024 * 10 as buffer length, PF sends 1448 string length back).
Do you have any suggestions how I can combat my issue?
The code below doesnt work, because at some point the content.Length > 0 but it is also the last batch of data.
void GetName()
    while (true)
            SendTCP(client2, "AUTHORIZATION password");
            Receive(client2);
            SendTCP(client2, "PLS_CURRENT_GET_ENTRIES");
            var content = Receive(client2);
            while (content.Length > 1024)
            SendTCP(client2, "PLS_CURRENT_NAME_GET");
            var data = Receive(client2);
So question is: what is the last character of a socket response or what is the max length of it?
Even if there is such character, "\n" perhaps, is it 100% sure that it is at the end and not splitted in 2 batches?
I am sorry, but these are C# coding questions - which I can not answer here in this forum ;-)
So you'll still receive an example code here, but in general I do not answer C# coding questions here - these should be addressed to other forums...
using System;
using System.Threading;
using System.Collections.Generic;
using System.Net;
using System.Text;
namespace ProppFrexx.RemoteControl
    /// <summary>
    /// Represents a TCP remote control client which is able to send commands and receive replies to and from a remote control server.
    /// </summary>
    /// <remarks>The client remote controls the server.</remarks>
    public class RemoteControlClient : IDisposable
        #region IDisposable Members
        public void Dispose()
            Disconnect();
        #endregion
        private TcpClient _tcpClient = null;
        private NetworkStream _tcpStream = null;
        private Timer _pingTimer = null;
        private TimerCallback _timerDelegate;
        /// <summary>
        /// Creates a new instance of a TCP remote control client.
        /// </summary>
        public RemoteControlClient()
            // Create the delegate that invokes methods for the timer.
            _timerDelegate = new TimerCallback(Ping);
        /// <summary>
        /// Gets a value indicating, if the client is connected to a server.
        /// </summary>
        public bool IsConnected
            get { return _tcpClient != null && _tcpClient.Connected; }
        /// <summary>
        /// Connects the client to the TCP remote control server.
        /// </summary>
        /// <param name="host">The DNS of the remote control server to which you intend to connect.</param>
        /// <param name="port">The port number of the remote control server to which you intend to connect.</param>
        /// <param name="password">The authorization password of the TCP remote control server.</param>
        /// <returns>TRUE on success - else FALSE.</returns>
        public bool Connect(string host, int port, string password)
            _tcpClient = new TcpClient(host, port);
            _tcpClient.NoDelay = true;
            _tcpClient.LingerState = new LingerOption(false, 0);
            _tcpClient.ReceiveTimeout = 5000;
            _tcpClient.SendTimeout = 5000;
            if (_tcpClient.Connected)
                // get the network stream
                _tcpStream = _tcpClient.GetStream();
                // send authorization
                string reply = Send("AUTHORIZATION " + password + Environment.NewLine + Environment.NewLine);
                if (reply.StartsWith("OK" + Environment.NewLine))
                    // start the ping timer
                    _pingTimer = new Timer(_timerDelegate, null, 5000, 5000);
                    return true;
                else
                    Disconnect();
                    throw new Exception("Remote Authorization failed!");
            return false;
        /// <summary>
        /// Disconnects the client from the TCP remote control server.
        /// </summary>
        /// <returns></returns>
        public bool Disconnect()
            if (_pingTimer != null)
                _pingTimer.Change(Timeout.Infinite, Timeout.Infinite);
                _pingTimer.Dispose();
                _pingTimer = null;
            if (_tcpStream != null)
                _tcpStream.Close();
                _tcpStream.Dispose();
                _tcpStream = null;
            if (_tcpClient != null)
                _tcpClient.Close();
                _tcpClient = null;
            return true;
        /// <summary>
        /// Sends the TCP remote control message to a server.
        /// </summary>
        /// <param name="tcpMessage">The message resp. command to send.</param>
        /// <returns>The servers reply message on success - else an exception will be thrown.</returns>
        /// <remarks>
        /// Note: This command blocks
        /// </remarks>
        public string Send(string tcpMessage)
            if (!IsConnected || _tcpStream == null)
                throw new Exception("Not connected to the TCP remote control server.");
            // the tcp message (must be terminated with a double CRLF)
            if (!tcpMessage.EndsWith(Environment.NewLine + Environment.NewLine))
                if (!tcpMessage.EndsWith(Environment.NewLine))
                    tcpMessage += Environment.NewLine + Environment.NewLine;
                else
                    tcpMessage += Environment.NewLine;
            string reply = String.Empty;
            lock (this)
                byte[] bufferSend = Encoding.UTF8.GetBytes(tcpMessage);
                _tcpStream.Write(bufferSend, 0, bufferSend.Length);
                if (!tcpMessage.StartsWith("BYE"))
                    // Read the reply (must also end with a double CRLF)
                    byte[] bufferRead = new byte[_tcpClient.ReceiveBufferSize];
                    int len;
                    DateTime _timeout = DateTime.Now;
                    do
                        // Read can return anything from 0 to numBytesToRead.
                        // This method blocks until at least one byte is read.
                        len = _tcpStream.Read(bufferRead, 0, _tcpClient.Available);
                        if (len > 0)
                            reply += Encoding.UTF8.GetString(bufferRead, 0, len);
                        else if ((int)(DateTime.Now - _timeout).TotalMilliseconds > _tcpStream.ReadTimeout)
                            break;
                    while (!reply.EndsWith(Environment.NewLine + Environment.NewLine));
            return reply;
        private void Ping(object stateInfo)
            try
                Send("PING" + Environment.NewLine + Environment.NewLine);
            catch
                Disconnect();
There is no defined length of the reply, you basically loop until you receive all bytes.
Note, the reply also ends with a double CRLF.
Here is an example to read commands from a file and send them all one by one and receive the replies...
private static bool ProcessCommandFile(string host, int port, string password, string fileName)
    bool ok = true;
    try
        string[] commands = File.ReadAllLines(fileName);
        if (commands != null)
            using (RemoteControl.RemoteControlClient remoteClient = new RemoteControl.RemoteControlClient())
                ok = remoteClient.Connect(host, port, password);
                if (ok)
                    foreach (string command in commands)
                        if (String.IsNullOrEmpty(command))
                            continue;
                        Console.WriteLine("Processing Command: {0}", command);
                        string result = remoteClient.Send(command);
                        Console.WriteLine(result.TrimEnd());
                        if (result.StartsWith("ERROR")
                            ok = false;
                    remoteClient.Send("BYE");
                    remoteClient.Disconnect();
                else
                    Console.WriteLine("Connect to server '{0}:{1}' failed!", host, port);
    catch (Exception ex)
        Console.WriteLine("ERROR: {0}", ex.Message);
        ok = false;
    return ok;
Thijmen
Post by Thijmen »
Awesome, I only had to check for the double line endings. Thank you so much!
