Track playback events
Maartenvn
Post by Maartenvn »
Hi Bernd
I am looking to use some events in ProppFrexx to trigger some specific external actions. Whenever a track plays in the playlist, inside an embedded container or inside an overlay I need to trigger a specific action.
  • Track plays in the playlist: I can use "OnTrackPlay", so that is already working
  • Track plays in an overlay in the overlay scheduler: I can use "OnOverlayTrackPlay", so that is already working
  • Track plays in an overlay, that has been resolved to the playlist: This doesn't work for some reason. The "OnOverlayPlayTrack" event is not triggered here. Is this a bug or does this event only trigger when an overlay is played in the overlay player? Is there another event that I can use to get the track information here? If not, would it be possible to integrate a new event here?
  • Track plays in an embedded container: As far as I am aware there is no event for this. The "OnTrackPlay" is only triggered on the container itself, not on the entries in the container. Can an event (eg: "OnEmbeddedContainerTrackPlay") be added here?
Thank you in advance
Re: Track playback events
When an overlay is resolved to the playlist, it doesn't trigger any "OnOverlayPlayTrack" events, as it is not played by the overlay anymore (it is not played by the Overlay Player), so instead the "OnTrackPlay" event would be raised, as this is triggered by the DJ Player of the playlist, as it is now played here.
I am not sure, if I can add such event, as for embedded containers, a continuous single stream for the entire container tracks is build. But I will take a look, but can not promise anything.
Maartenvn
Post by Maartenvn »
Thanks for the answers!
The problem is that the OnTrackPlay event is not triggered for the items in the overlay, but rather for the entire overlay itself. I need to know which tracks are played in the overlay.
I assume, as overlays that are resolved to the playlist are also embedded containers, the same solution would be possible here.
Yes, that was explained in the other item and is exactly the same.
Do you (only) need to know which tracks are played or or it also important that it triggered exactly at the time when they are played?
Maartenvn
Post by Maartenvn »
I would need to know track information like trackname, mediatype, ... and if possible also the trigger time ${effectivestart}, as I need to synchronise event time between systems.
I need to know at which time the track is played, not just which tracks are available in the overlay, as I am doing some real-time actions.
Okay, here are two options, which are available today - choose yourself, what might better fit to your use case:
1) Use the Streaming.OnSongTitleChanged event (instead of Playlist.OnTrackPlay):
The OnSongTitleChanged event already supports raising the event also for embedded container tracks. Just go to the general settings, section Streaming and set the "Use Embedded Container Tracks" option for the "Streaming Options":
And the use the Streaming.OnSongTitleChanged event to trigger your action...
2) Expand the embedded container entries to the LOG files, i.e. the EXEC_WRITE_GLOBAL_LOG and the EXEC_WRITE_PLAYLIST_LOG commands:
This options writes individual entries of the embedded container to the resp. log file.
