On-Air Time Window
dsharpless
On-Air Time Window
Post by dsharpless »
Hello I have v4.3.4.5 64-bit
I selected dock on the options on the "On-Air Time" window and it disappeared, it does not show anymore when I select it in the ribbon. I saw an earlier post, saying to delete the "layout" option for windows in users appdata however that doesn't exist on my computer. (Windows 10 Home version 21H2) can you help me please.
Re: On-Air Time Window
It is probably just hidden behind another dock panel?
However, in the Windows Explorer the default setting is, that Windows hides all extensions of the files, ie. you won’t explicitly see the .layout extension and as such only see the ‚ProppFrexx ONAIR‘ file - actually probably multiple, as it could be the ‚ ProppFrexx ONAIR.config‘ or ‚ ProppFrexx ONAIR.layout‘. Regardless, the file is for sure existing.
See here: https://www.thewindowsclub.com/show-fil ... in-windows
If you cannot find the file you can also go to the general settings, section Look & Feel and click on the ‚Reset: Layout‘ button. A restart if ProppFrexx is required after.
Like explained here: https://www.proppfrexx.radio42.com/foru ... 796#p17796
