Exec_send_email
Inzane8305
Exec_send_email
Post by Inzane8305 »
Hi Bernd.
Trying to setup the MAIL SETTING in GENERAL SETTINGS I get an error:
It looks as if proppfrexx wants to send "AS" [email protected] and not with sender mail?
I get and error as well when using a GMAIL or ONE.COM account.
Kindly advice me ;-)
Re: Exec_send_email
Go to the general settings and click on the "Mail Settings..." button to open the related dialog.
The FROM address as specified in this dialog will always be used (if empty, the from address as specified in EXEC_SEND_MAIL command will be used, else the from address of the command is ignored).
Inzane8305
Re: Exec_send_email
Really sorry for not explaining this the right way.
It is in fact when setting up MAIL settings in general settings that the error occurs.
And it still seems that your (proppfrexx email) settings are "trying" to be the "sender" (if I'm reading the error message correct.?)
Kind regards Kjeld B.
Re: Exec_send_email
Yes, the "Test..." mail is indeed send 'from' proppfrexx - which is not correct!
I will correct that in the next version.
However, please make a test with EXEC_SEND_MAIL - this should work as designed and described. THX
Inzane8305
Re: Exec_send_email
Indeed it does.
THX !!
