Playlist columns size
Bob Van Dongen
Hello all
I had the following question I did the last update of Proppfrexx but from now on I can no longer narrow the front 3 columns ( Player # Schedule) in the playlist. Is this still possible and if so how? thank you very much for your response
Regards Bob van Dongen
Re: Playlist columns size
There was once a bug in v4.3.3.7 - which has already been resolved, see here: https://www.proppfrexx.radio42.com/foru ... hp?p=17471
But in the end the user also had to do the following:
When you close PF, pls go to the AppDataFolder and delete the ProppFrexx ONAIR.Playlist.layout resp. …Playlist2.layout files and/or any other layout file to which you have saved the playlist layout to.
Then restart PF.
Then restart PF.
Bob Van Dongen
thanks for your quick reply, i'll check it out tomorrow
Bob Van Dongen
Is this the file I need to delete? doubt because there is no layout behind it, but I don't have that file
Yes it is.
You have probably hidden your file extensions in the windows file explorer (which is often the default, but equally confusing).
Here is how to show all file extensions: https://www.thewindowsclub.com/show-fil ... in-windows
Bob Van Dongen
Thank you for your message it worked
