Open PFL Player using separate executable
Maartenvn
Post by Maartenvn »
It would be handy to be able to open the PFL Player as a separate audio player using a separate executable.
This way the ProppFrexx PFL player can be used directly inside scheduling tools like MusicMaster, which have an External Mediaplayer option.
The executable would take the input file path and open it in the PFL editor.
Re: Open PFL Player using separate executable
I guess there are hundreds of existing media players out there?
But I can think about it!
Maartenvn
Post by Maartenvn »
That is true 😄
This is more on a practical standpoint. We would be able to open the PFL player and edit the Cues for a song from inside of MusicMaster, without having to:
* Open the file in file explorer
* Drag it into the ProppFrexx tagger
* Open the PFL player and change the cues
Since v4.3.4.x there is a separate ProppFrexx Player executable available.
See here: https://www.proppfrexx.radio42.com/foru ... php?t=3340
