Upper case only Artist
could you add a checkbox to uppercase for artist only? ...for playlist view, for write to txt file, etc.... Thank you....
Re: Upper case only Artist
Not sure. But you can already enter all Artists in uppercase.
Not sure, if I want to automatically sanitize and convert meta data just for you - I guess everyone wants it different.
I understand, but that's not what I mean. In the settings there is an option "Upper Case Tracks". I would split it for "Artist" and "Title".
That doesn’t make much sense to me. I understood it that way. So you want Artists in upper case, but not the Title?!
I guess this won’t be implemented.
It's clearer in the playlist, but also on RDS. Here in the Czech Republic, this display is widely adopted.
- test.png (7.54 KiB) Viewed 52344 times
And renaming everything is quite challenging...
Could something be done about it?
Currently there are no plans. Because what you want is not only a visual polishing (like the Use Upper Case Track option), but also a complete uppercase also for all interfaces, e.g. events, notifications and macros. Basically an automatic correction of all meta data.
As such, I suggest, that you mass change your meta data of your tracks with an external tag editor...
