Adv campaign start day
RadioDada
Post by RadioDada »
Suddenly, when I want to register a new advertising campaign, whatever start date I set, the program registers the campaign with the current date. Have I enabled/disabled any general settings by mistake? How could I go back to the previous situation where I can register campaigns with the desired start date?
Re: Adv campaign start day
Here it doesn’t happen. Can you post a screenshot, so that I maybe better understand what exactly you mean?
As a test I just created a new campaign (today, on the 4th of Dec. 2022), and specified a Start Date of the 1st of Dec.
There was also nothing changed in any of the latest versions.
RadioDada
Post by RadioDada »
Looking at the screenshot in your message, I think I understand what's happening: for one reason or another I can't expand the "Campaign" window and I can't see and access the "Ok" and "Cancel" buttons. As a result, by not validating the changes I make, is normal it not be saved. How can I expand this window that seems to be stuck? I don't have a maximize button, I can't expand from any side or corner...
What is your screen resolution and DPI setting on your PC? Normally each dialog should scale automatically. For whatever reason this seems to be broken on this dialog. I need to check this as well?!
A new v4.3.3.7 is available!
It contains a bug-fix for High-DPI settings for a few dialogs like the Campaign Edit one. So I hope this is resolved now!
RadioDada
Post by RadioDada »
Thank you very much for your help. I fixed it and everything is fine now.
