Input and Output on AXIA
This forum is unmoderated!
ketofm
Post by ketofm »
Hello
i have 4 players each have its own Axia Livewire sound card and setup with GPIO
Livewire 01
Livewire 02
Livewire 03
Livewire 04
i have ASI PCI ASI6685 Livewire sound card 8 in/out channels in my PC too
when my song loading to DJ A B C D or anyone the sound card changes to ASI PCI ASI6685 Livewire sound card and i can't hear the song which i did not set up for ASI PCI sound card...
i only setup up for Axia sound card Livewire 01. 02, 03, and 04 for my GPIO setup
I need those not ASI PCI ASI6685
Livewire 01
Livewire 02
Livewire 03
Livewire 04
Re: Input and Output on AXIA
The Default Routing looks okay to me.
But do you need the Alternative Routing - it doesn’t look to me, so disable those options.
And the only option I can think of (why the output might change) are the Routing per Media Type…. I cannot see from here, if you have defined those. If yes, remove all these options.
I am also not sure, why you need DJ A, B, C and D as Input devices? But these shouldn’t impact your case.
And I wonder, as I thought, that Benjamin will setup all for you? Didn’t he?
ketofm
Post by ketofm »
Thank you
i'll work on it
YES, Benjamin is great he did great JOB Thank you
Axia GPIO is working but some to go
