cartwall
Radiostar929
cartwall
Post by Radiostar929 »
Hi Bernd when using cart wall is there a single keyboard command button to play the mp3 in the cartwall folder?
Re: cartwall
When the related cartwall window has the focus you can use the numpad keys to start/stop the related cart.
But you can also use the general Keyboard Mapping (see general settings, section GPIO/Remoting) to map any key stroke and key value to a related control-command. I.e. use e.g. the "CW1_PLAY_CART X" command and replace the X with the number of the cart you would like to play.
Radiostar929
Re: cartwall
can you clarify how to use the num pad with the cart wall i dont understand only alt+5 works as a command
Re: cartwall
Each modern keyboard has a num-pad area (see screenshot).
When the cartwall panel is activated and focused you can press on these numbers (e.g, 1) to play/stop the cart 1.
Radiostar929
Re: cartwall
can you explain activated and focused i have tried the num pad numbers and they do not trigger the cart items
Radiostar929
Re: cartwall
i found it now thanks
