v4.3.3.11 - stable
v4.3.3.11 - stable
Version 4.3.3.11 is out!
What's New?
  • Bug-Fix for High-DPI settings for a few dialogs
  • Bug-Fix for Remote-Voice Tracking program selection
  • Upgrade to latest BASS audio engine versions
  • Downmix truncation at Fixed TUS optimized
  • TLS/SSL support for streaming
  • Updated OGG, OPUS and FLAC encoders to support ICEcast2 mid-stream meta updates
  • Optional Bitstream metadata updates for FLAC, OGG and OPUS
  • Updated of all other encoders to its latest version
  • New macro-function ${RCM:clientname|macro} to resolve remote macros
  • New macro function *[FILENAME: added
  • LoadPlaylist now always evaluates file changes, also for Overlays
  • RVT now also resolves Overlays for already created/imported playlists
  • Advertising: Billing now allows multi-period selection, plus Campaign Filters
  • Advertising: New Fix-Price per month calculation option
  • Advertising: Dynamic Slot Assignment Filters allow multiple entries
  • Bug-fix for script-line mode 'Execute' and the ResetScriptPointer option
  • Bug-Fix FLAC Encoder config
  • Bug-Fix when supressing an Overlay and resuming a Playlist
  • New UseBASS option for EncoderProfiles (might disable internal encoders)
  • New Threads setting for Mixer-Output-Channels
  • Placeholders starting with an !-sign are not replaced during VT
  • Livewire+ mapping Bug-Fix
  • Various optimizations and smaller bug-fixes
  • stable
Streaming enhanced (e.g. ICEcast):
Beside TLS/SSL support, all encoders have been updated to the latest version. But most important is the support for mid-stream meta data updates, which require new bitstreams when using OGG, OPUS or FLAC OGG streams. This is now automatically supported.
In addition an option was added to suppress the metadata update via a new bitstream option, which is e.g. needed for the RSAS server.
Macro-function ${RCM:clientname|macro}:
Normal macro's are evaluated locally. With this new macro you can evaluate macros on a remote ProppFrexx instance.
The connection to that remote instance is configured in the Remote Control Monitor as a Remote Client. As such, the first parameter denotes the related client name. The second parameter is the name of the macro. Example...
Locally: ${cpltracknamecurrent}
Remote on MainPC: ${RCM:MainPC|cpltracknamecurrent}
See the User Manual Appendix for examples...
Re: v4.3.3.7 - stable
Version 4.3.3.7 is out!
A new version was necessary to fix a High-DPI settings bug for some/few dialogs.
Pieter
Post by Pieter »
Do you saw that in this new version first column is wider? You can't make it smaller either.
See the link for an example
https://kickfm.nl/images/after_update_4337.mp4
Maybe you can take a look at this?
Thanks
Regards,
Pieter
Re: v4.3.3.8 - stable
A new v4.3.3.8-update is available.
Re: v4.3.3.11 - stable
A new v4.3.3.11-update is available.
It just contained a small bug-fix related to the KeepStreamLoading option for the LoadTrack script-line mode, which caused a 'file not found' error when using a URL instead of a file.
In addition a new 'IsolateAdvertsAndJingles' script option as added: The script based Adverts and Jingles are not immediately checked after each line, but only if this was not a Cartwall or Advert entry resp. only at the end of a LoadPlaylist, Execute and LoadFolder block (and not after each line).
