countdown clock
Radiostar929
countdown clock
Post by Radiostar929 »
Hi Bernd. How are you Need some help. I lost the big digital countdown clock the other day and do not know how to get it back. Help Please. Tom
Re: countdown clock
Then your layout seems to be broken or you have accidentally moved the clock window to an invisible location.
You can do to things:
A) close ProppFrexx, locate the file called „ProppFrexx ONAIR.layout“ in your ProppFrexx AppUserData folder, delete that file, and finally restart ProppFrexx.
B) go to the general settings, section Look And Feel and click on the button ‚Reset: Layout‘ (not ‚Restore Layout…‘)! A restart of ProppFrexx is also required.
