Mixer does not show!
JWvanGulik
Post by JWvanGulik »
Hi, the mixer does not show up. Not with the button in the ribbon, and also not with Ctrl+M. Help!
Re: Mixer does not show!
Then your layout seems to be broken or you have accidentally moved the mixer window to a invisible location.
You can do to things:
A) close ProppFrexx, locate the file called „ProppFrexx ONAIR.Layout“ in your ProppFrexx AppUserData folder, delete that file, and finally restart ProppFrexx.
B) go to the general settings, section Look And Feel and click on the button ‚Reset: Layout‘ (not ‚Restore Layout…‘)! A restart of ProppFrexx is also required.
JWvanGulik
Solved! Thanks again for your quick reply, Bernd. Have a good weekend. BRJW
