volume ducking on voice tracking.
fjb59
Post by fjb59 »
hi when voice tracking is there anyway to make the ending/ starting sung duck in volume when i either knock the mic fader up or when it picks up volume on my mic?
Re: volume ducking on voice tracking.
Sure, you can create a volume curve - a double-click on the upper half of the wave form adds a volume point, which you can then drag and drop. When you click on the Attenuate button a default curve is created.
fjb59
Post by fjb59 »
radio42 wrote: 06 Aug 2022 15:44 Sure, you can create a volume curve - a double-click on the upper half of the wave form adds a volume point, which you can then drag and drop. When you click on the Attenuate button a default curve is created.
that worked. thank you
