On-screen fader to control Ember+ capable console
Moduu
Post by Moduu »
Hello!
Do you think it would be possible to control a Ember+ capable console from PF, like a fader level of microphone channel? I do have an Lawo box which does not have any physical control surface, so it would be beneficial to be able to send level commands via Ember+. Yes, I can do it manually with Ember Viewer :)
Re: On-screen fader to control Ember+ capable console
Yes, that should be possible. You can send (ember) commands when you move the mixer fader of ProppFrexx.
Use the events commands when you right-click on the mixer-channel name and then select "Edit Control Commands Events..." and then select the 'OnFader' entry…
