downmix chain
This forum is unmoderated!
fjb59
downmix chain
Post by fjb59 »
if i use the downmix option to export tracks to an audio which mixers process chain does it use (eq, compression etc)?
Re: downmix chain
When you downmix a track or multiple tracks, you can choose to also use the DSP chain.
This chain is defined separately and specifically innige general settings, section Mixing/Fading. In this section you can define 4 VSTs to use for any downmix operation.
