voice tracking on one side
This forum is unmoderated!
fjb59
Post by fjb59 »
I'm not sure if this is a bug but whenever i try to record a voice track, it records it to a stereo file with the audio all on one side. it does this depsite how a fiddle with the encoder settings. i am having to manually change the track to mono in an external editor. is there a way around this?
Re: voice tracking on one side
In the related mixer input channel (from which you are recording) you can set the 'Mono' option.
In addition you can also right-click and specifiy the mono processing option, as explained here:
https://www.proppfrexx.radio42.com/foru ... 7064#p7064
fjb59
Post by fjb59 »
radio42 wrote: 29 Jul 2022 16:57 In the related mixer input channel (from which you are recording) you can set the 'Mono' option.
i must have looked at that four or five times and didn't see it. thanks for that :)
