Playlist on website
Bernarddemol
Playlist on website
Post by Bernarddemol »
Hello
I am new to proppfrexx. And I had a question.
Is it possible to upload automatic the playlist without advertising, jingles, voice track something like this https://www.vbro.be/playlist/
Thanks a lot
Re: Playlist on website
Sure. Take a look at these older posts, they describe various possibilities:
https://www.proppfrexx.radio42.com/foru ... php?p=2366
Or
http://www.proppfrexx.radio42.com/forum ... ?f=9&t=730
Try a search here for ‘Now Playing’...
I hope this guides you in the right direction. In the general settings, you can even define, what Event Entry types should be used for streaming and title updates. Eg. you can also completely manually use the Streaming.OnSongTitleChanged event and update your web site manually.
