v4.3.1.0 - stable
v4.3.1.0 - stable
Version 4.3.1.0 is out!
What's New?
What's New?
- new UI lib update
- new Audio lib update
- new 'Artist Match' automatic Sweeper selection for Artist Intro features
- EXEC_WRITE_PLAYLISTFILE doesn't write BOM for json files
- new Script-Line mode HookQueue
- new control-command PLS_CURRENT_APPEND_SCRIPT added
- new control-command VT_PLAY_CART and VT_TALKOVER added
- new control-command SHOW_MESSAGE_BOX added
- new macros added ${plstrackguidcurrent}, ${plstrackguidnext}, ${cpltrackguidcurrent}, ${cpltrackguidnext}
- various optimizations and smaller bug-fixes
- stable
Re: v4.3.1.0 - stable
Installed, but after the installation, proppfrexx starts normally again, but not now. Also the shortcut on the desktop does not work .
Fixed , my faultKekke wrote: 10 Jul 2022 12:37 Installed, but after the installation, proppfrexx starts normally again, but not now. Also the shortcut on the desktop does not work .
Good afternoon
After the last update, Proppfrexx no longer starts automatically.
If I start it manually.
I see it start up in the task manager and then shut down automatically.
Can you see where it goes wrong?
Hopefully answer before 17.00. because I have a live broadcast at 7pm.
Sincerely,
Wesley Winands
Sincerely,
Wesley Winands
No, it works for many other users just fine.
Do you see any error message in the file called Error.log!
Please also check, if there is a license issue or Ident-Number change and what last message is shown at startup, eg. where ProppFrexx got stuck…
Hi Bernd,radio42 wrote: 10 Jul 2022 14:21 No, it works for many other users just fine.
The following log file Erro.log
10-7-2022 14:31:01 [v4.3.1.0]:********** Error/Exception Information
Error Message: The type initializer for 'DevExpress.Utils.AppearanceObject' threw an exception.
Error Type: System.TypeInitializationException
Error Source: DevExpress.Utils.v22.1.Void
set_DefaultFont(System.Drawing.Font)
Inner Exception: Could not load file or assembly 'DevExpress.Drawing.v22.1, Version=22.1.3.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. Het systeem kan het opgegeven bestand niet vinden.
at DevExpress.Utils.AppearanceObject.set_DefaultFont(Font value)
at Fq.NW.Main(String[] args)
Error Message: Could not load file or assembly 'DevExpress.Drawing.v22.1, Version=22.1.3.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. Het systeem kan het opgegeven bestand niet vinden.
Error Type: System.IO.FileNotFoundException Error Source: DevExpress.Utils.v22.1.Void .cctor()
at DevExpress.Utils.AppearanceObject..cctor()
at System.Environment.GetStackTrace(Exception e, Boolean
needFileInfo)
at ProppFrexx.ProppFrexx_ONAIR.AGiB(Exception )
at ProppFrexx.ProppFrexx_ONAIR.QGiA(Exception )
********** End **********
I can't find a new license key because proppfrexx doesn't even start.
As I mentioned, I see it start up but immediately shut down in the Windows task manager window.
Greetings Wesley
Hi Wesley,
the error indicates, that a new dll is somehow missing in the installation folder (not sure why, but I just cleared all caches and uploaded the installations/updates again).
You can also find the missing dll here: https://proppfrexx.radio42.com/download ... .1.dll.zip
Just unzip it to your ProppFrexx installation folder.
Many Greets and sorry for any inconvenience,
Bernd
Bernd
wesleyw wrote: 10 Jul 2022 14:44Hi Bernd,radio42 wrote: 10 Jul 2022 14:21 No, it works for many other users just fine.
needFileInfo)
Greetings Wesley
Its Fixed with the missing file.
Thanks Bernd for your support!
Greets Wesley
Steve FamilyRadio
Hello Bernd, could you tell us a bit more about the new function - new 'Artist Match' automatic Sweeper selection for Artist Intro features.
Thank you!
Thank you!
Sure. The so far existing feature picked a (length matching; eg. to fit into the Ramp time) track RANDOMLY from the selected cartwall lib.
This generates a nice, but general sweeper.
The new option does something similar, with a few changes:
- it also selects a random track from the cartwall, but filtering the cartwall with ONLY tracks matching the same Artist! This allows picking (if available) an Artist related intro sweeper, eg. to announce/feature the Artist.
- it always uses the mentioned transition, eg. if the Artist intro is too long (longer than the ramp time), the sweeper stays as a dedicated track within the playlist.
