ACPD does not work in Tagger
Thijmen
Post by Thijmen »
I just found out that ACPD does not work in the Tagger application. When I open the file in ProppFrexx ONAIR, the button ACPD in PFL Player works fine.
Thijmen
Re: ACPD does not work in Tagger
Post by Thijmen »
Not sure if you've seen this message, bump.
Just tested it here, and the button ACPD in e.g. the PFL Player of the Tagger application works as designed just fine.
Same is true when you right click in the Tagger and select Selection -> Calculate AutoCuePoints
So I can not experience any issues.
