start playlist script with user login
This forum is unmoderated!
jbmusic
Post by jbmusic »
i would like to start a specific user-playlist script.
When i read the manual i see this options is available, but when i check the user profile or user settings, i am not able to select this. Where can i find this option, so i can help the users, with a basic playlist (from script) which is started after login.
running version: 4.2.7.2 enterprise edition
Re: start playlist script with user login
What exact option are you talking about?
jbmusic
Post by jbmusic »
In the manual you see when you add a user that you can select a script playlist.
This would be helpful when a user login and Pf will play the playlist script as selected
I am sorry - I don't see that option in the manual?!
What exact page are you one - or post a screen-shot?
That option however never existed.
Maybe you meant the 'Playlist Script Template' - which is now handled automatically (this this combo-box is removed) - but this option was never starting a certain playlist when a user logs in.
What you can do is call any control-command when a user logs in - see 'On User Login' in the Library tab.
E.g. you might use the PROGRAM_STARTSCRIPT command.
See the Appendix for details for that command.
