Weather setup
davefrmn2019
Weather setup
Post by davefrmn2019 »
Need help setting up a display in ProppFrexx for written weather forecast. Also for automated temperatures.
Re: Weather setup
For automated temperatures you can use the ${weathercurrenttemperature} macro.
See the Appendix in the User Manual for other available ${weather...} macros.
A right-click on the weather panel lets you setup you location, language and various other options and also here you can set your own https://openweathermap.org/ private API key.
Here is a link describing on how to setup a weather announcement: https://www.proppfrexx.radio42.com/foru ... php?t=1846
davefrmn2019
Re: Weather setup
Ok I have a api key...what are the steps to enable the temperatures ?
Re: Weather setup
Enter the API key.
And then set your location and language.
That’s it.
davefrmn2019
Re: Weather setup
Where do i enter my API key ?
Re: Weather setup
As said: you make a right-click in the weather window. This shows a popup menu…
davefrmn2019
Re: Weather setup
Bernd,
Weather window at Proppfrexx ? i don't know where that is ?
Re: Weather setup
In the Control Room & Message Center panel.
davefrmn2019
Re: Weather setup
I only see Click here to set location & OpenWeatherAPI Key Needed. I don't see where to enter my API weather key.
Re: Weather setup
Again: when you make a right-click a popup menu appears. This contains beside the location and language menu items also an item called ‚Set private API key‘.
