Bug in PFL player
maspi80
Bug in PFL player
Post by maspi80 »
Hello. This is my first post.
I have noticed a bug in the PFL player. When you set the In and Out points using the keyboard.Accidentally pressing the I and O keys simultaneously will crash the entire program.
Re: Bug in PFL player
Unfortunately I can not reproduce the issue. I have tested this on several machines several times, but my machine never crashes.
Can you safely reproduce this?
However, can you please check, if you can find a related entry in the ProppFrexx file called "Error.log" (located in the ProppFrexx AppDataUser folder; e.g. %appdata%\radio42\ProppFrexx ONAIR\4.0\)?
If yes, please send this file to me.
If not, the error probably occurred somewhere else in your system but definitely not in ProppFrexx, maybe you can find more information in your Windows Event Log?
