How to insert jingles
Ihor Mudrak
Post by Ihor Mudrak »
Dear colleagues, could you please help me to put into my playlist 6 jingles of our internal radio?
Re: How to insert jingles
Create a cartwall library in which you put all your Jingles.
You can then use this media lib to assign it the cartwall windows, so that each jingle is shown as a cart, which you can play via a simple click.
You can also use the cartwall lib and use these in your script for automatic playback.
But your question is not really clear, what you are looking for.
Ihor Mudrak
Dear colleagues, we are new for Proppfrexx radio software so please help us.
Now we have around 600 tracks in our playlist and 6 jingles. How to organize our script so the playlist could go around 24/7 and each 3 tracks play one of 6 jingles (randomly)?
The easiest way is the following:
1) you create a media lib (e.g. a folder based) in which you place you 600 music tracks, let's call this MUSIC
2) you create a cartwall lib in which you place you 600 jingle tracks, let's call this JINGLE
3) you create a script (let's call it DAILY, see below)
4) you open the program scheduler and create a recurring program, e.g. from 00:00:00 to 23:59:59, recurring every 1 day,
- Start Type: SOFT ; Options: uppressLateStartRollForward, ForceLateStartBeginning
5) you click on the "Run Scheduler" ribbon tab button
Here is the simple script:
For detailed help, please see the tutorial videos:https://www.proppfrexx.radio42.com/foru ... php?t=1018
Ihor Mudrak
Thank you, Bernd! Where should I add the Cartwall with Jingles?
In the Scheduler Ribbon tab, you can manage your media, cartwall and script libraries.
So do it like your media lib, just as a cartwall lib.
Ihor Mudrak
I mean how to insert the cartwall with jingles into the air?
Right-click drag & drop
Ihor Mudrak
Thank you, Bernd! You helped a lot! Going to watch you tutorials to get more information.
