Moderator text
djbony
Moderator text
Post by djbony »
if the track contains moderator text, would the envelope symbol appear in the line and after clicking on it, the moderator text would appear in the window?
Thanx, P.
Re: Moderator text
I will think about it.
Note, that there is a Moderator button at the very bottom left statusbar next to the light bulb icon. When you click on it you can display the moderator text window in which you can directly and separately display the moderator text of the current (and optionally the previous and next) track.
This was already designed to help serving the same purpose probably - what do you think, reap. are you currently using this already?
djbony
Re: Moderator text
Post by djbony »
I don't use it because I use the moderator text as additional information to a few songs. And if I don't see clearly that the song contains this information, it doesn't make sense. That cover could be displayed just below the serial number of the song in the playlist - there is an unused space :)
Re: Moderator text
The layout of the playlist and the columns can all be freely arranged, and I don’t know what serial number you mean.
However, I might take a look, but not sure, if my when this will make its way into the product.
djbony
Re: Moderator text
Post by djbony »
I mean here...
Snímek obrazovky 2022-01-15 231517.png (10.39 KiB) Viewed 6690 times
