control command for scheduler automation
moogwill
Post by moogwill »
Is there any control command for scheduler automation (pre-generation) to be inserted in a reminder; or attached to a specific event ?
Thanks.
Re: control command for scheduler automation
Can you explain what function you exactly mean?
Do you mean the manual function "Create Playlist Entry..." when you right-click on a program entry?
However, there is currently no further control-command for the scheduler automation (except to import external log files via PROGRAM_IMPORT).
Note, that you can automatically pre-generate certain Program-Scheduler entries (if that is what you are looking for)?
Click in the general settings, section Folder/Libraries on the "Scheduler Automation..." button. In the upcoming dialog you can specify when you want to start the "Automatic Playlist Template (Pre)Generation". E.g. you can only do this for certain program types, or certain program names etc.
