script disappears in the library.
Erris
Post by Erris »
If I create a new script, and save it with ok, then the script is not shown in the library, but the script is not in the directory either.
if I create a new script with the same text, my previous script settings are remembered.
If I restart Propp it works fine.
Re: script disappears in the library.
There must be some magic on your PC, as ProppFrexx doesn’t delete, remove, hide or recreate anything by itself.
But if now all is working fine, that’s good. Maybe you had some rights issue on your device or user? Unfortunately I cannot really tell you what that was/is.
But I am pretty sure it is not a ProppFrexx issue, as I cannot reproduce that, nor have I heard that from any other user.
Erris
Post by Erris »
Thanks Bernd, I think it's also a rights issue, I work with windows 2022 propp is running like clockwork.
this was the only problem, hope it's gone. Otherwise dig into the server logs :)
