v4.2.7.5 - stable
v4.2.7.5 - stable
A new version 4.2.7.1-.5 is out!
What's New?
  • new UI lib update
  • new Audio lib update
  • new EXEC_COMMAND_ONALLREMOTES control-command
  • Remote MediaLibs now supports creating a LocalStorage
  • Immediate Find Window TAG reading bug-fix
  • Track Insert Transition Attenuation bug-fix
  • Restore Sorting bug-fix
  • Remove All Settings added to Tagger application
  • Tagger PFL doesn't automatically loop at end
  • Script LoadPlaylist mode now supports a |shuffle option
  • new control-command PLS_CURRENT_MOVE_TO added
  • Binary RegEx mode added to Serial GPIO
  • various optimizations and smaller bug-fixes
  • stable
Pirana
Re: v4.2.7.1 - stable
Post by Pirana »
I installed Proppfrexx on a new clean Windows 11 machine. Installatiopn was ok, but I cannot install the 4.2.7.1 update. There was an error on creating a directory or file. Then the installation is aborted. Of course i tried the administrator option, but this also gave the same error.
Unpacking of the update file, gave an error of the advertising executable. (??)
With regards Roy.
Thanks, I need to check, where the error is.
Pirana
Post by Pirana »
4.2.7.2 Did automatically install after a upgrade popup. So problem solved!
moogwill
Re: v4.2.7.2 - stable
Post by moogwill »
hi, what exactely is medialib local storage?
For 'Remote Media Libraries' you can now define a Local Storage path, which is simply a local folder.
If specified, a remote media entry (file) will be copied to this local storage location whenever accessed (e.g. via a script-line or thru an external log import). This way a local storage is build dynamically. The next time the entry is validated, if the file exists locally, if yes, it is directly used.
Caution: Over time, a fully copy of all remote files are created, so make sure enough space is available locally.
This way you might create a local copy of a remote media lib over time to reduce network traffic. This feature was especially build for a very large customer as an optional feature. In most cases I assume, that no other customer needs this feature. As said, it create a copy in a plain and quite simple way.
Re: v4.2.7.4 - stable
The v4.2.7.4 update now contains new EXEC_COMMAND_ONALLREMOTES control-command
moogwill
Post by moogwill »
thanks, will have a look tonight
Re: v4.2.7.5 - stable
I don’t maintain the old versions, but only the latest v4.3.0.0.
Why would you use the old version? There is no reason to not use the latest one. If that should be related to your MIDI issue, I can ensure, that nothing was changed in the MIDI part. Also note, that only your slider messages seems to have an issue, but other MIDI messages work fine. So that can not be related to the new version.
The previous version is with any update you perform in ProppFrexx stored in the sub-folder of the installation folder called ‚previous version‘.
