Tag Editor remember last folder
Peter Maerlandt
Post by Peter Maerlandt »
Is it possible to ad this option to Tag Editor: "Tag Editor opens at last used folder" (yes/no) or "open at default folder (choose folder)".
I personally would like to have the first option.
Best Regards, Peter.
Re: Tag Editor remember last folder
The Tagger application got two new comamnd-line options:
-last : starts the Tagger with using the last opened folder
-open path : starts the Tagger with using the specified folder
Exaample:
"ProppFrexx Tagger.exe -last"
"ProppFrexx Tagger.exe -open C:\Music"
A new v4.2.6.13-beta is available - so select "Check for Beta-Versions..." to update (located under to blue question mark icon at the very top right).
Peter Maerlandt
At this moment I feel stupid: how do I work with command-line?
You just add the command-line when starting the executable, eg. „ProppFrexx Tagger.exe -last“
Eg. create a new shortcut on the desktop or right-click on the existing menu item in the existing start menu and also right-click and edit it’s properties.
Here you just edit the start command and add the command-line option.
When you Google for it you will find a lot of examples.
Peter Maerlandt
Peter Maerlandt wrote: 03 Dec 2021 20:45 At this moment I feel stupid: how do I work with command-line?
As in the movie "Philadelphia": explain it to me like i'm a 6 year old.
I'm sorry, this is the result:
I also tried via the program's shortcut, but that's also not working...
The hidden window is the correct one - there you specify/add the command-line. Where you also specify the exe and after it you just add the -last command-line.
Peter Maerlandt
radio42 wrote: 04 Dec 2021 17:17 The hidden window is the correct one - there you specify/add the command-line. Where you also specify the exe and after it you just add the -last command-line.
Thanks, It's obvious as I now know it. This function works great. Thanks again.
Cool - thanks
