adding listeners count for each song, show
phonic
Post by phonic »
Is it possible in ProppFrexx Statistics to display listener count collected from streaming data so it displays as a column within the ?
I assume I need to add ${streamingtotallisteners} to the global logs but do I need to add an extra header for new column?
Re: adding listeners count for each song, show
Nothing to add or do, the ProppFrexx Statistics application and log file already contains a column called 'ListenerCount', which contains the number of listeners at that moment as measured by the ProppFrexx ONAIR streaming server(s).
phonic
Post by phonic »
radio42 wrote: 30 Nov 2021 19:00 Nothing to add or do, the ProppFrexx Statistics application and log file already contains a column called 'ListenerCount', which contains the number of listeners at that moment as measured by the ProppFrexx ONAIR streaming server(s).
Thanks for your reply.
I was thinking that would be the case as I checked the raw logs and could see the listener data, but can't found any such column in the application. I must have something not enabled or doing something wrong. I'll have another more detailed check.
phonic
Post by phonic »
I've had a more detailed look at the application this evening and the only reference to ListenerCount I could find is in Snap Report Designer:
The Pivot and Table grids do not have a column called "ListenerCount" that I can add:
That is correct. The Listener Count is currently only available/visible for the Snap Reports.
But I can add that to the Data and Pivot Grid as well in the next version!
phonic
Post by phonic »
radio42 wrote: 30 Nov 2021 23:51 That is correct. The Listener Count is currently only available/visible for the Snap Reports.
Adding it to the grids would make it very useful for seeing listener trends in relation to shows and timings.
I will look forward to that update.
Already done in the latest v4.2.6.12!
phonic
Post by phonic »
radio42 wrote: 01 Dec 2021 22:22 Already done in the latest v4.2.6.12!
Already updated to the latest version. Thank you.
