Separate playlist for standby player
franksiegers
Post by franksiegers »
Would it be possible to have one or more standby players that each have their own playlist?
That way, we could have interviews and other special audio fragments in a separate playlist, separated from the main music playlist.
Ideally, it would be absolutely great if each standby player's audio could be routed to a separate channel, instead of sharing one channel with all standby players, but having it's own playlist would already be great!
Have a good night,
Frank
Re: Separate playlist for standby player
You can define as many Standby Player as you like.
Each can be switched to the stack mode (see image). This allows you to load a stack/mini playlist.
When you right-click on the Standby-Player name, you can even specify for each standby player and Output Device (output channel).
So, yes, all that is already possible.
