Trackboard problem
tatje
Trackboard problem
Post by tatje »
Hey,
I have in the trackboard on one of the tabs a reference to a folder where I have music files.
if I remove this music file via the trackboard "remove selected track" and actually remove the track in the folder, the track reference keeps coming back in the trackboard and also in the folder where the original track was located a dead track.
regards, Tatje
Re: Trackboard problem
If you physically delete a file from the Trackboard (e.g. via SHIFT+CTRL+Del or via the context menu) the file will be physically deleted from the folder!
If the file magically 'comes back' - this has nothing to do with ProppFrexx, as ProppFrexx can not and does not recover any files.
For possible solutions you need to find the real root cause, which might be causing this, as for example explained here:
https://www.easeus.com/resource/files-f ... d%20prompt.
or here:
https://recoverit.wondershare.com/cloud ... -back.html
tatje
Post by tatje »
Thank you Bernd,
the problem is solved because you put me on the right track.
the problem was in the permissions of the server.
Regards, Tatje
