Moderator/Track info window
Farbo
Post by Farbo »
Maybe this is not a bug. When setting to show previous and next track info in moderator window (separate standalone window) after restart of PF desing of this window is set back to default layout and not the one lastly used.
Peter
Re: Moderator/Track info window
I am affraid I can not reproduce your issue.
The Moderator/Track info window restores as it should be here (after a restart of PF).
Meaning the settings (Show Previous/Next Track) are maintained.
Please give some more details on what exactly can be
Farbo
Post by Farbo »
I can not give you more info besides that when restarting PF Track/Moderator is set back to default layout. It is useless to send you any printscreens, it has simply its default layout and the one I set lastly, i.e. see next and previous tracks. Strange is that option "lock to current playlist" is still there. Is it by default?
Peter
Farbo
Post by Farbo »
I installed the newest version but no change so far. Moderator window after PF restart goes into default settings.
Peter
I am unable to reproduce this issue here!
I tried it on 3 different machines and on all rhe window position and settings have been restored correctl.
So please explain what you mean by it is restored to its default.
Maybe we are talking about different things.
Farbo
Post by Farbo »
Please, see attached. Default view is loaded always when restarting PF. But I use the "new" view. It is simply not saved, I think.
From the "new" view you can also see the problem with album art.
DEFAULT:
Moderator info_default.jpg (163.9 KiB) Viewed 18918 times
NEW:
Moderator info_new.jpg (233.3 KiB) Viewed 18918 times
Peter
Now I see what it might be causing (not restoring the layout correctly).
A new v3.0.10.36 will fix that, which is now available!
Farbo
Post by Farbo »
Thank you Bernd. Works fine now. Great.
Peter
