Mod stream
DizgoRadioFM
Mod stream
Post by DizgoRadioFM »
We are using the Mod Stream for our live shows.
Its possible to put a track before the stream start and when you finish.
My question is it maybe also possible to select a random begin or end file ?
Now you can only select 1 file.
So you can give every live show a diffrent start and begin.
Re: Mod stream
Currently you can select only a single file. But I can try to take a look.
E.g. in a next release you might select a playlist file (e.g. a .pfp file) and in that case a random file would be selected out of that playlist. Pretty much like the intro/outro files for e.g. overlays.
DizgoRadioFM
Re: Mod stream
That would be great.
Then we can play random into’s for the live shows.
Re: Mod stream
The v4.2.6.7-beta now contains the option to specify a playlist file as the intro/outrofile.
I use the beta version please choose "Check for Beta-Versions..." under the help menu at the very top right underneath the '?' icon.
