Live Dj Set Input automatc unmute
dj wildboy
Hello, I would like to set up the program sceduler so that the analog input in the mixer is automatically unmute for a live broadcast. A LiveDJ set should be imported from a Dj mixer. Hardware and in the Proppfrexxmixer everything is set up so far. It would also be important that the overlays continue to run.
Re: Live Dj Set Input automatc unmute
You can use the events associated with the program, e.g. the 'On Program Started' event (click on the 'Control Commands...' button in the Program Editor dialog) to trigger a command (e.g. MIXER_INPUT_MUTE_ON INP1).
The execution of overlays is independent of that and can be configured in the general settings, section Scripts/Scheduler.
All control commands and its use/parameter are listed in the Appendix of the User Manual.
