Bug in Quick Acces Toolbar
DJSven
Post by DJSven »
Hallo,
Whem i put the open from the ribbon in tool acces Toolbar und hide Ribbon. Then i Start the software New the mini Icon is Damage and un usebel. After every Newstart must i delit the icon and put it new in the tool acces Toolbar. Ribbon Style is office 2007 and Style is Metropolis Dark. Version the latest
Re: Bug in Quick Acces Toolbar
Unfortunately I do not fully understand your issue.
Can you try to explain the steps to reproduce? And maybe show a screenshot of what is not working properly?
DJSven
Post by DJSven »
Ok nun auf Deutsch
es gint tool exess bar (kleines ICON)
Ribbon (große Icon)
für ich das große icon in die kleine bar und zwar nur das icon öffnen
wenn ich das system neustarte das das icon defekt und kann nicht megr zum offen verwendet werden - ich muss nach neustart das icon neu hinzufühgen und das alte löschen
I am currently on holiday and will check this when I am back on the 14th of October.
The issue seems to be only happening with the 'Open' ribbon ribbon item, when adding it to the QuickAccess toolbar.
Unfortunately it seems to be an issue with the UI lib which I am using. I will address this with the vendor, but I am afraid it will need some time to solve this issue, especially as it seems to be not really critical.
DJSven
Post by DJSven »
thanks, i wate
Fixed in v4.2.6.5!
