Presets lists open behind COMP,AGC,EQ window
phonic
Post by phonic »
Presets lists now open behind the current open window.
Here's a screen host of the Compressor,and EQ windows with the preset list opening underneath:
You can still select if needed using the arrow keys.
Re: Presets lists open behind COMP,AGC,EQ window
Good spot! This is actually a bug in the new version of the UI lib which I am using. I reported it to the vendor and waiting for feedback!
The UI vendor already fixed that bug, which is applied in v4.2.6.3!
