Proppfrexx Tagger
Peter Maerlandt
Proppfrexx Tagger
Post by Peter Maerlandt »
I open a new .FLAC file in Meta data Editor and I write some Genre (for example: 'Disco' and 'Dance' )
Next time I open ProppFrexx Tagger, the last Genre is only beeing readed (in my example that is 'Dance), however the .FLAC file still has the 2 original Genres in it.
After changing something to the Meta Data and saving the file, the original field is overwritten and has only the last genre ('Dance')
I might be wrong, but didn't ProppFrexx allowed us to use multiple Genre's?
Re: Proppfrexx Tagger
Yes, but you need to separate them with a comma or semicolon as far as I remember.
djbony
Post by djbony »
I have some questions too. If I set TempoIn or TempoOut in Tagger, it ends it in error. In PFOA - the data will not be stored...
If I want to save more data in the Style field, it also doesn't work. F (female) will be saved without any problems, but if I add another one - for example CZ as a Czech song, it will not be saved. I also can't make a mass change in Tagger. Previously, I marked, for example, 20 tracks and en masse rewrote the year of release. I can't do it now. I'm doing something wrong?
What exact error do you get?
Mass changes effect all selected track - nothing has changed there, so yes, something must be wrong. I will test that again tomorrow- but first I also need to know, what errors you get.
djbony
Post by djbony »
If I increase the TempoIn/Out, I get this:
********** Error/Exception Information **********
Error Message: Určené přetypování není platné.
Error Type: System.InvalidCastException
Error Source: ProppFrexx Tagger.Void akU(System.Object, DevExpress.XtraTreeList.CellValueChangedEventArgs)
v ProppFrexx.Explorer.akU(Object , CellValueChangedEventArgs )
v DevExpress.XtraTreeList.TreeList.RaiseCellValueChanged(CellValueChangedEventArgs e)
v DevExpress.XtraTreeList.TreeList.PostEditor(Boolean causeValidation)
v DevExpress.XtraTreeList.TreeList.OnActiveEditor_LostFocus(Object sender, EventArgs e)
v System.Windows.Forms.Control.OnLostFocus(EventArgs e)
v DevExpress.XtraEditors.BaseEdit.OnLostFocus(EventArgs e)
v DevExpress.XtraEditors.PopupBaseEdit.OnLostFocus(EventArgs e)
v System.Windows.Forms.Control.WmKillFocus(Message& m)
v System.Windows.Forms.Control.WndProc(Message& m)
v System.Windows.Forms.TextBox.WndProc(Message& m)
v DevExpress.XtraEditors.Mask.MaskBox.MaskStrategy.ManagedStrategy.DoWndProc(Message& m)
v DevExpress.XtraEditors.Mask.MaskBox.WndProc(Message& m)
v DevExpress.XtraEditors.TextBoxMaskBox.WndProc(Message& msg)
v System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
********** End **********
Peter Maerlandt
djbony wrote: 30 Aug 2021 21:14 Hi,
I also have the same problem: in earlier days one could select multiple songs and change one or more fields, e.g. year or genre or tempo. Since some time this is not possible.
Found the bug and your reported issues!
They will be fixes asap in the next release. Thanks for reporting.
djbony
Post by djbony »
Great! Thank you too.
Peter Maerlandt
Thanks, looking forward.
Fixed in v4.2.6.0!
