ID3 Title update for live input
dj wildboy
Post by dj wildboy »
Title update for live input. A musician should play a track live in the studio. The whole thing via the analog input of the sound card, so no ID3 tag transmission. How can I solve it anyway, that an ID3 tag is transmitted to the server, for example via a silent overlay which is manually started. Or can this also be done via a normal playlist whose channels are muted or the PlaylistPlayerchannel lEvel -60db in the mixer. So can I somehow transfer defined ID3 tags
Re: ID3 Title update for live input
If you ‚just‘ want to set the song title of your broadcasting server, you can use the control-command STREAMING_SET_SONGTITLE or even set it manually in the network streaming monitor window of ProppFrexx, right-click into it and select ‚Set Song Title…‘.
dj wildboy
Perfect :-) Thanx Bernd
