v4.2.5.1-3 - stable
v4.2.5.1-3 - stable
Version 4.2.5.3 is out!
What's New?
  • new UI lib update
  • Track Scripting Restrictions are now honored for AutoJingles
  • better support for ftps with EXEC_DOWNLOAD/UPLOAD_FILE
  • Requirement of own private OpenWeatherMap API key added
  • new macros added (e.g. ${cw1/2cartNremaining}, see User Manual Appendix)
  • honor Restrictions also for FTE
  • option to update the entry statistic also from within the MODStream
  • new ${albumart500} macro
  • various PFL_ macro comamnds added
  • OpenWeatherMap now based on free version
  • various optimizations and smaller bug-fixes
  • stable
Farbo
Re: v4.2.5.1 - stable
Post by Farbo »
After update I found maybe one error. When I mark few songs in playlist and do right click (for example for PFL mixing), my selection is unmarked. Or is it some new setting which I have to change?
Peter
I can not reproduce that here?! After selecting multiple tracks in a playlist and making a right-click tye context menu comes up normal and nothing is deselected.
Farbo
Post by Farbo »
Sorry, I am not able to record video of that behaviour because when I record it I do not see the PF context menu in video even though ir appears there in reality.
Peter
I guess now I see what you mean. It seems indeed to be a different behavior in the new UI lib I am using. I have to check with the vedor, why hey changed this behavior.
It does however not happen, if you right-click on the last row you selected (that's even how I tested it).
Farbo
Post by Farbo »
Thank you Bernd. I clicked in the middle I think. I will test if at least clicking on last row works.
Peter
Re: v4.2.5.3 - update
A new version v4.2.5.3 is out - so 'Check for Updates...'!
In which I fixed the change in the UI lib behavior (resp. made a workaround for it internally) mentioned above.
