Error after opening Scheduler
TomNick
Post by TomNick »
I am getting the following error after trying to open the scheduler:
19.06.2021 13:43:09 [v4.2.4.2]:********** Error/Exception Information **********
Error Message: Value does not fall within the expected range.
Error Source: DevExpress.Utils.v20.2.DevExpress.Utils.DirectXPaint.ID2D1Bitmap CreateBitmap(DevExpress.Utils.DirectXPaint.D2D_SIZE_U, IntPtr, UInt32, DevExpress.Utils.DirectXPaint.D2D1_BITMAP_PROPERTIES1 ByRef)
   at DevExpress.Utils.DirectXPaint.ID2D1DeviceContext.CreateBitmap(D2D_SIZE_U size, IntPtr srcData, UInt32 pitch, D2D1_BITMAP_PROPERTIES1& bitmapProperties)
   at DevExpress.Utils.DirectXPaint.Direct2DImages.CreateDirect2DBitmapUnsafe(Bitmap bmp)
   at DevExpress.XtraScheduler.Drawing.AppointmentStatusSkinPainter.Draw(GraphicsCache cache, AppointmentViewInfoStatusItem item)
   at DevExpress.XtraScheduler.Drawing.DayViewTimeCellAppointmentSkinPainter.DrawAppointmentItems(GraphicsCache cache, ViewInfoItemCollection items)
   at DevExpress.XtraScheduler.Drawing.AppointmentPainter.DrawForegroundCore(GraphicsCache cache, AppointmentViewInfo viewInfo, Rectangle viewClipBounds, ISupportCustomDraw customDrawProvider, Boolean isGroupAppointment)
   at DevExpress.XtraScheduler.Drawing.AppointmentPainter.<>c__DisplayClass118_0.<DrawForeground>b__0()
   at DevExpress.XtraScheduler.Drawing.AppointmentPainter.DrawAppointment(GraphicsCache cache, AppointmentViewInfo viewInfo, ISupportCustomDraw customDrawProvider, Boolean isGroupAppointment)
   at DevExpress.XtraScheduler.Drawing.DayViewTimeCellAppointmentSkinPainter.DrawAppointment(GraphicsCache cache, AppointmentViewInfo viewInfo, ISupportCustomDraw customDrawProvider, Boolean isGroupAppointment)
   at DevExpress.XtraScheduler.Drawing.AppointmentPainter.DrawAppointmentsCore(GraphicsCache cache, IEnumerable`1 aptViewInfos, ISupportCustomDraw customDrawProvider)
   at DevExpress.XtraScheduler.Drawing.AppointmentPainter.DrawContainerAppointments(GraphicsCache cache, IEnumerable`1 appointments, ISupportCustomDraw customDrawProvider, SchedulerViewCellContainer container, Int32 scrollOffset)
   at DevExpress.XtraScheduler.Drawing.AppointmentPainter.DrawAppointments(GraphicsCache cache, SchedulerViewInfoBase viewInfo, SchedulerViewCellContainerCollection containers, ProcessAppointmentType selection)
   at DevExpress.XtraScheduler.Drawing.AppointmentPainter.DrawAppointments(GraphicsCache cache, SchedulerViewInfoBase viewInfo, ProcessAppointmentType selection)
   at DevExpress.XtraScheduler.Drawing.DayViewDispatchAppointmentPainter.DrawAppointments(GraphicsCache cache, SchedulerViewInfoBase viewInfo)
   at DevExpress.XtraScheduler.Drawing.DayViewPainter.DrawAppointments(GraphicsCache cache, SchedulerViewInfoBase viewInfo)
   at DevExpress.XtraScheduler.Drawing.ViewPainter.DrawAppointmentsAndTimeIndicator(GraphicsCache cache, SchedulerViewInfoBase viewInfo)
   at DevExpress.XtraScheduler.Drawing.ViewPainter.Draw(GraphicsCache cache, SchedulerViewInfoBase viewInfo)
   at DevExpress.XtraScheduler.Drawing.DayViewPainter.Draw(GraphicsCache cache, SchedulerViewInfoBase viewInfo)
   at DevExpress.XtraScheduler.SchedulerControl.PaintCore(GraphicsCache cache)
   at DevExpress.XtraScheduler.SchedulerControl.TryPaint(GraphicsCache cache)
   at DevExpress.XtraScheduler.SchedulerControl.OnPaint(PaintEventArgs e)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at DevExpress.XtraScheduler.SchedulerControl.WndProc(Message& m)
********** End **********
Re: Error after opening Scheduler
Are you just opening the scheduler ?
Have you changed anything in your setup or configuration?
Or tried to reboot your machine?
And is it the overlay scheduler or the Programm scheduler?
In any case, it would be great, if you can send me the related .calendar file.
TomNick
Post by TomNick »
Solved after reboot
TomNick
Post by TomNick »
Running in the same problem again, sent you the error log. Problem appears when I am trying to edit in the regular scheduler
I saw it, but we should solve it here. Could it be, that the .calendar file gets corrupted, eG. by a hardware defect?
TomNick
Post by TomNick »
Hardware is brandnew (about 4 weeks old) and it worked for a while, the error appeared out of the blue....
Something must be corrupting it, as this error doesn’t happen in general or with other users.
So please send me your .calendar file once the error happens.
TomNick
Post by TomNick »
<Items>
<Appointment Version="1" Start="06/03/2021 07:45:00" End="06/03/2021 08:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Location="Normal Rotation" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="" />
<Appointment Version="1" Type="1" Start="06/05/2021 00:00:00" End="06/06/2021 00:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Rotation Neu" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<RecurrenceInfo Start="06/05/2021 00:00:00" Id="c2f75fa3-ac03-4659-910c-42512d0ac960" Version="1" />
<Reminders>
<Reminder AlertTime="06/25/2021 23:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Version="1" Type="3" Start="06/06/2021 00:00:00" End="06/07/2021 00:00:00" TimeZoneId="W. Europe Standard Time" AllDay="True" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Rotation Neu" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<RecurrenceInfo Id="c2f75fa3-ac03-4659-910c-42512d0ac960" Index="1" />
</Appointment>
<Appointment Version="1" Type="1" Start="06/06/2021 18:00:00" End="06/06/2021 20:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="NDW" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="NDW" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<RecurrenceInfo Start="06/06/2021 18:00:00" WeekDays="9" Id="a9e182d2-cfa6-4789-b0e1-5ab0d7aaa470" Type="1" Version="1" />
<Reminders>
<Reminder AlertTime="06/27/2021 17:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Version="1" Type="4" Start="06/06/2021 18:00:00" End="06/06/2021 20:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="NDW" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="NDW" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<RecurrenceInfo Id="a9e182d2-cfa6-4789-b0e1-5ab0d7aaa470" />
</Appointment>
<Appointment Version="1" Type="1" Start="06/08/2021 18:00:00" End="06/08/2021 20:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="70s" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Totally 70s" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<RecurrenceInfo Start="06/08/2021 18:00:00" WeekDays="4" Id="586cf4f1-f6d4-46f1-9352-570abe19e187" Type="1" Version="1" />
<Reminders>
<Reminder AlertTime="06/29/2021 17:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Version="1" Start="06/12/2021 20:00:00" End="06/12/2021 23:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAIAAAAL" Location="Saturday Night" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Saturday Night" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="" />
<Appointment Version="1" Type="1" Start="06/15/2021 20:00:00" End="06/16/2021 00:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Rotation Neu" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<RecurrenceInfo Start="06/15/2021 20:00:00" WeekDays="4" Id="4cde94d2-a0fe-4bb7-ad75-6e4350ab301e" Type="1" Version="1" />
<Reminders>
<Reminder AlertTime="06/29/2021 19:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Version="1" Type="1" Start="06/16/2021 20:00:00" End="06/17/2021 00:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Rotation Neu" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<RecurrenceInfo Start="06/16/2021 20:00:00" WeekDays="8" Id="f1f3a0b1-a50b-425b-98be-43b2b9cd9b5d" Type="1" Version="1" />
<Reminders>
<Reminder AlertTime="06/30/2021 19:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Version="1" Type="1" Start="06/20/2021 20:00:00" End="06/21/2021 00:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Rotation Neu" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<RecurrenceInfo Start="06/20/2021 20:00:00" WeekDays="1" Id="2265c2c8-a4df-4b0d-8730-854d2bfcaad0" Type="1" Version="1" />
<Reminders>
<Reminder AlertTime="06/27/2021 19:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Version="1" Start="06/19/2021 20:00:00" End="06/19/2021 23:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAIAAAAL" Location="Saturday Night" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Saturday Night" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="" />
<Appointment Version="1" Start="06/19/2021 23:00:00" End="06/20/2021 02:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Rotation Neu" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="" />
<Appointment Version="1" Start="06/20/2021 02:00:00" End="06/20/2021 05:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAIAAAAL" Location="Saturday Night" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Saturday Night" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="" />
<Appointment Version="1" Start="06/20/2021 05:00:00" End="06/20/2021 18:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Rotation Neu" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="" />
<Appointment Version="1" Start="06/26/2021 20:00:00" End="06/26/2021 23:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAIAAAAL" Location="Saturday Night" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Saturday Night" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<Reminders>
<Reminder AlertTime="06/26/2021 19:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Version="1" Start="06/26/2021 23:00:00" End="06/27/2021 00:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Rotation Neu" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<Reminders>
<Reminder AlertTime="06/26/2021 22:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Version="1" Start="06/27/2021 02:00:00" End="06/27/2021 05:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Saturday Night" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Saturday Night" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<Reminders>
<Reminder AlertTime="06/27/2021 01:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Version="1" Start="06/27/2021 05:00:00" End="06/27/2021 18:00:00" TimeZoneId="W. Europe Standard Time" Label="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAEAAAAL" Location="Rotation Neu" Status="~Xtra#Base64AAEAAAD/////AQAAAAAAAAAEAQAAAAxTeXN0ZW0uSW50MzIBAAAAB21fdmFsdWUACAAAAAAL" Subject="Rotation" MaxDelay="120" MixTime="0" Overlay="0" ReloadScript="False" CommandStarting="" CommandStarted="" CommandSuspended="" CommandResumed="" CommandStopping="" CommandStopped="" AddToMessageCenter="False" Command="" IsReminder="False" UserConfirmation="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="" Options="0" MaxEarly="0" MaxLate="0" Priority="0" InitialTrack="" AutoPlayCondition="">
<Reminders>
<Reminder AlertTime="06/27/2021 04:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
</Items>
I used your calendar entries and had absolutely no issue. I was using it several times over the day. Closed PF, re-opened it; opened and closed the program scheduer multiple times etc. - no issues.
So it must be somewhere in your environment, which makes the .calendar file unusable...
Are you maybe using any copy/sync software in the background, which accesses or modifies the file? Or access the file from multiple PCs? Or something like this?
TomNick
Post by TomNick »
There was a calendar lock file. I deleted that and now it looks like working again.
