Add video support
Guancha
Add video support
Post by Guancha »
Hello. Forgive my English but I am Spanish. I am using ProppFrexx demo for several weeks. I like how it works but I don't like that it doesn't support video files. I think they should update so that it supports video and we can use it in complement with OBS Studio, vMix ...
Most automators already support it, such as Dinesat, Ominiplayer, Jazler ...
If I had this function I would buy without hesitation ProppFrexx
Thank you
Re: Add video support
A partner implemented a special solution for dedicated video solution and its sync. I might connect you with: [email protected]
Or are you only interested in playing the audio of certain video files, which is already possible for certain file, but no t for all.
However, there is no immediate plan to add video file support.
Guancha
Post by Guancha »
The idea is to add videos of the new songs. The old ones will continue only in audio. Only audio will be used in our FM station, but video can be included for our website and social networks.
The future of radio is to use visualradio with both cameras and video clips for better interaction with listeners.
As said, than you should contact Per, as he has an extension for a visual audio solution!
