Fading option
Radiofreak
Fading option
Post by Radiofreak »
When i disable fading in the top bar the fading option is disabaled till the next hour. When the next hour starts after the TOTH overlay the fading option automatically turn back to enabled. Is ther away to let it disabled for the time being?
Re: Fading option
No. The fading option is set per every playlist window.
The only option would be to not start the next hour in a new playlist window, but use the same playlist window. Eg. use the TimeUpdateSync start types…
Radiofreak
Re: Fading option
I use the TimeUpdateSync start types all the time. Too bad it is not possible.
Re: Fading option
You still can switch off the fading manually via a control command using the On Program Started event ?!
Radiofreak
Re: Fading option
Tested and it works indeed. Sometimes it is so very simple, but you just have to know how... :D ;)
Thanks again for this beautiful peace of software Bernd.
